Posi for my 91 RS??
Old Jan 11, 2007 | 06:51 PM
jjohnston's Avatar
Car: 91 Camaro RS
Posi for my 91 RS??
I want to get a posi for my 91 RS? Anyone know where I can get one? I found gears, but, I would like posi as well. Is it possile to convert my current rearend to a posi?
Old Jan 12, 2007 | 12:53 AM
cam92rs's Avatar
Car: 25th anniv. camaro
Engine: 305 tbi
yes, it is most likely easier to find a rear end(from a iroc z or z28) that is posi and has a decent amount of gear (that you want, i hear most have 3.42's. i just recently bought a posi (from a tgo member) from a newer f body. i have a set of gm's 3.73's from a monte carlo ss. you need to know the axle spline count( your car is a 91, the the spline count is 28) as far as converting your 10 bolt to a posi unit with some gears, i will tell you tomarrow. im goin out to my old technical school (mechanic, auto tech) and will be doing my swap in my 92 rs. i mnot sure what kind of problems i will run into. im not sure if i will need new shims and what not. this is goin to get interesting. if you find drain89 or somthing like that, he seems to know alot about this kinda stuff.
also remember. the series carrier (posi unit)you will need, i think anyhting below 3.08 is 2 series, and anything above 3.23 is 3 series?
im sure im missing a few details. but im tired and have been searching this site for a posi install for a while now,lol.
Old Jan 12, 2007 | 05:03 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Have you though of just putting in a limited slip? Auburn makes a good product. You could pick one up from Summit. While not a posi it should do the job.
Old Jan 12, 2007 | 07:09 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
A posi is a limited slip for your info....Positration (AKA posi) was Chevelot trade name for a Limited Slip rear in the 60's.
Old Jan 12, 2007 | 09:15 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Heres some good reading for you.
http://en.wikipedia.org/wiki/Limited_slip_differential
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
