Engine out. Should I replace the Torque Convertor?
Hi guys,
I've got the engine out for replacement just now. My 89 350TPI L98 dropped a valve and died! I've already got numerous mods, including Lingenfelter runners, ported base, ported plenum, larger TB, Hooker 2210's, true duals, etc.
The torque convertor that's in the car doesn't lock up. I think it may have been changed for a slightly higher stall speed and to a non-lock up model by a previous owner.
One of my friends, RMK, changed his TC for a higher stall Vigilante and saw a good improvement in acceleration.
Would you recommend replacing it whilst the engine is out?
Thanks.
Thanks.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
I agree. While the motor is out and you're rebuilding, go for the upgrade on those hard to access items.
Good luck
Good luck
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Vigilante puts out quality converters from what I hear. I'd say somewhere in the range of 2,800 to 3,200 would be good to have and still be friendly on the street.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
