More power. What to do with the TH700?
Old Jan 19, 2007 | 05:16 AM
GTAsweden's Avatar
I´m installing a new cam and balancing the engine (Trans Am GTA 350).
The cam I´ll be using is this: http://store.summitracing.com/partde...0&autoview=sku
What needs to be done with the transmission (TH700)?
I got this list from a member of the swedish Trans Am Club.
From Transmission Parts USA:
35764CK $21.79
13 Vane Pump Upgrade 2 heavy duty vane rings, 13 slot rotor guide, 13 slot rotor, 13 vanes
From Bulk Part
A74654A $16.43
Sprag low/reverse wide
A74658B $41.85
Sprag forward 29 element dual cage
74200 $12.61
Thrust Washer Kit
74201A $16.45
Bearing Kit
T74167 $25.38
TransGo Shift Kit Jr. (at least this, if not a full blown shift kit)
A74584C $67.50
5 Pinion Rear Planetary
D74582B $164.66
5 Pinion Front Planetary
A74905BAK $16.90
Servo Kit & Boost Sleeve Corvette servo, new 1-2 and 3-4 accumulator pistons, and new TV boost valve and sleeve
T54450A $9.30
Adjustable detent cable (TV cable) 700R4
A74536K $0.43
Pump Slide Spring Kit
Transmission Center
11CF $19.00
Alto Carbon Fiber 2-4 Band
14-2 $205.00
Alto Red Eagle Master Rebuild Kit gasket and seal kit, metal clad seals, ring kit, all Red Eagle Performance clutches, all high performance kolene steels, high performance 3-4 Red Eagle power pack.
45 $298.00
Extreme Duty Torque Drive Package hardened input shaft and new input drum, beast reaction shell, new low reverse sprag hardened input gear trimmed w/thrust bearing to replace thrust washer.
Old Jan 20, 2007 | 08:23 AM
Pro Built Automatics's Avatar
35764CK $21.79
On pumps that did not come with a 13 vane setup, this will lose oil volume.
From Bulk Part
A74654A $16.43
Sprag low/reverse wide This is ok.
A74658B $41.85
Sprag forward 29 element dual cage This is ok.
74200 $12.61
Thrust Washer Kit This is ok.
74201A $16.45
Bearing Kit This is ok.
T74167 $25.38
TransGo Shift Kit Jr. (at least this, if not a full blown shift kit) You need the modified TransGo Performance Shift kit.
A74584C $67.50
5 Pinion Rear Planetary Waste of money, and not necessary.
D74582B $164.66
5 Pinion Front Planetary Waste of money, and not necessary.
A74905BAK $16.90
Servo Kit & Boost Sleeve Corvette servo, new 1-2 and 3-4 accumulator pistons, and new TV boost valve and sleeve This is ok.
T54450A $9.30
Adjustable detent cable (TV cable) 700R4 This is ok.
A74536K $0.43
Pump Slide Spring Kit Get the TransGo No Yo Yo steel ring kit here.
Transmission Center
11CF $19.00
Alto Carbon Fiber 2-4 Band Borg Warner Hi-Energy works best here.
14-2 $205.00
Alto Red Eagle Master Rebuild Kit gasket and seal kit, metal clad seals, ring kit, all Red Eagle Performance clutches, all high performance kolene steels, high performance 3-4 Red Eagle power pack. Not necessary!!!
45 $298.00
Extreme Duty Torque Drive Package hardened input shaft and new input drum, beast reaction shell, new low reverse sprag hardened input gear trimmed w/thrust bearing to replace thrust washer. Stay away from this.
Why don't look at what I have for this. I match it to your particular setup. Let me know if I can be of help?
Old Jan 20, 2007 | 01:00 PM
GTAsweden's Avatar
thanks for the info! I´ll let you know if I need to buy parts. I´m gonna check with the guy who´s doing the job with the transmission first.
meeklay812
Oct 1, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
lanceflame44
Sep 25, 2015 12:28 PM
middian
Sep 5, 2015 01:42 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
