torque converter question
Old Jan 21, 2007 | 10:32 PM
badazz84camaro's Avatar
i installed a converter in my th350, i did the spin thing and it dropped in the trans twice. to make sure it was seated i pulled the converter back a little and pushed it in and is sounded solid like it was seated all the way in the pump. i put the trans back up, making sure the converter spun while bolting it in and there is no clearance between the flywheel and converter but the converter spins freely??? is this good?? will it hurt anything??
Old Jan 21, 2007 | 10:35 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yeah it will spin freely, thats how they are
after youve installed so many you just know when you have it in all the way or not, second nature
its a special kind of lift spin wiggle push to get them in all the way, once you know how you always do
usually there is always a good amount of gap between the flexplate and converter, you might want to make sure its installed all the way, all the ones ive ever had have always had enough gap inbetween them to fit at least a couple washers inbetween them easily, if not more than two
good luck
Old Jan 21, 2007 | 10:59 PM
yeah usually they do, but this one didnt, i didnt have to pull it back and it sounded like it it bottomed out in the pump???
Old Jan 21, 2007 | 11:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd pull it and spin it some more, going both ways and wiggling up and down just to be safe, I usually can tell when it drops in since you can't see a gap around the converter and the bellhousing anymore
Old Jan 21, 2007 | 11:45 PM
yea i can too, it made two solid drops in the trans???
Old Jan 22, 2007 | 01:04 AM
xpndbl3's Avatar
Car: 1984 Z28
well then crank the motor over and if it pumps fluid out one of the lines if they're disconnected then you're good to go
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
