B&M Megashifter Problem
Old Jan 24, 2007 | 09:47 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
About a month back i would go to shift up or down and it wouldn't catch, i would do it again and i would shift. Then it straightned up and didn't do it again. Now i cant shift up into Neutral or down into 2nd or 1st. So i took the shifter out and noticed that the half moon shaped piece that is at the bottom that catches the teeth on the other plate is slipping on the plate, and its like its like the half moon piece is not going all the way to meet the plate to engage it.
Anyone else had this problem, also yall think i should get call summit because the shifter is only about 6 months old.
Old Jan 25, 2007 | 01:38 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I would defiantly be looking into that either with summit or calling B&M about that!
Old Jan 26, 2007 | 01:12 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Make sure that the cable is not binding as well, if it is, that can cause big problems...
Old Jan 28, 2007 | 06:26 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
No its not binding, when i push the plate that attaches to the cable by and try to shift, sometimes it will catch and try to shift. When the cable is disconnected, it will ratchet sometimes. With it on it wont ratchet at all. I think the extra resistance the cable produces is too much and the teeth on the shifter just slips, i just got a truck that im bout to start driving, im going to call summit to get them to replace it once i stop driving the maro.
Old Feb 11, 2007 | 10:34 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i just got a megashifter from a friend that owed me a little bit of money. anyhow, it seems to not wanna go past drive...havent put it in the car yet. also the reverse light assembly broke right off, and i need parts for it (new boot and some kinda shift plate). anyhow, can i get these parts, and what should i do about it not going past drive (from park). cant get it into third second, etc.
Old Feb 12, 2007 | 05:33 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Well the drive and reverse problems sounds like eighter the pin that goes acrouss the plates is messed up or the lever that you pull isnt coming all the way up. And you can get some of the parts for it here http://store.summitracing.com/partde...ew=4096&N=700+
Old Feb 12, 2007 | 06:20 PM
ZZ4 86 Z28's Avatar
i meant the hookup to the reverse position so the reverse lights will come on. and i think it actually might have been the neutral safety switch, come to think of it, but who needs that? anyhow, i still cant figure out why it will freely go from park to drive and back, but no further than drive.
Old Feb 12, 2007 | 07:09 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
once you get to drive, you have to release the small t-handle and ratchet it back to 1,2 and 3.
Old Feb 12, 2007 | 09:27 PM
ZZ4 86 Z28's Avatar
im aware. it just wont go any further. i just took it all apart and put it back together and still no dice. this thing is pissing me off. i let a lot of money go for this thing.
Old Feb 12, 2007 | 10:16 PM
ZZ4 86 Z28's Avatar
gave it one last shot...it works now. only thing is it can ratchet all the way back to neutral if i keep doin it. is that normal?
Old Feb 14, 2007 | 12:16 AM
4RCEPWRD's Avatar
Car: 82Z28
yes mine does that too, kinda worried me at first but now Im used to it.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
