1985 g92 option
Old 01-27-2007 | 04:39 PM
1991 RS 305's Avatar
1985 g92 option
I'm looking at a rear end out of an 85 Iroc. It has rear disc brakes. In my searches, being the car had an auto I can conclude that it has 3.23's or 3.42's. My question is did the disc brakes only come with the 3.42's (G92 option) and the drums with the 3.23's, or is it possible to have a 3.23 with disc brakes.
Thanks, Matt
Old 01-28-2007 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, that's what my car is equipped with.
Should you be unfamiliar, here's how to determine what ratio the rear is (jerk the diff cover and look): numbers are stamped on the ring and pinion:
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Old 01-28-2007 | 01:14 PM
Thanks for the info, JamesC. The guy e-mailed back and sayd it was a 3.42. He also said it wasn't a posi now. Is this even possible, rear out of an 85 Iroc, 3.42, with disc brakes, but not a posi? I would think that the disc brake option alone would make it a posi. The rear has sat fo 20 years, they removed the drivetrain from the car back in 87. is it possible that the wheels are spinning opposite due to it sitting for so long and some parts being dry?
Old 01-28-2007 | 04:34 PM
JamesC's Avatar
IIRC, the posi was an option. If that's the case, then, yes, the rear could be a disc brake rear and not be posi equipped. One way or another, you might request that the seller remove the diff cover and check.
JamesC
gixxer92
05-18-2017 11:20 AM
Lbibb
05-05-2016 12:00 AM
Bubbajones_ya
10-25-2015 08:01 PM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: 1985 g92 option
