Where to place tranny temp sensor?
Old Jan 27, 2007 | 10:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I bought a B&M transmission temperature gauge for my 700R4. I'm wondering where the sensor should be installed- I believe it's 1/8" NPT. I have aftermarket flexible lines to my cooler so installing a T fitting would be very easy, but I don't know if adding more hose clamps is the best idea. I have the stock pan, is it worth installing a fitting? What would be the best way to do this?
Old Jan 29, 2007 | 12:19 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
I just put it in my trans pan no problems
Old Jan 29, 2007 | 12:54 AM
Car: 86 T/A
Engine: HSR 355
What did you use to mount it (since there's no stock fitting)?
Pro Built Automatics's Avatar
Put it in the return line (top line), this will give you the best results in that you will see how well your cooling system is doing.
Old Jan 30, 2007 | 12:08 AM
Car: 86 T/A
Engine: HSR 355
I'm not familiar with the pressure in the lines or anything which is why I ask this:
I have a B&M cooler which has hose clamps keeping the lines on tight, would cutting the line and hose clamping a T-fitting in be a secure way to do it? I'm really concerned with the thought of hacking my hoses or causing any reliability issues.
GTAman
Jul 3, 2024 07:29 PM
Bstrang6
Sep 8, 2015 04:29 PM
willyjoejr
Sep 3, 2015 09:26 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
