'91 Camaro Tranny help
Old Jan 31, 2007 | 12:08 AM
park8b156's Avatar
Car: 91 Camaro RS
Engine: Right now 350
Transmission: s
Axle/Gears: stock
Ok I plan on puting a 383/450hp or a 383/400hp motor in my car and I need a realy good trany to go with it. But I don't know where to look or what to get can you all give me some tips. Thanks!
Old Jan 31, 2007 | 12:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
automatic or manual? You can get a beefed up 700R4 to work, or swap to a non-overdrive beefed up TH350 or TH400. For a manual, either a Tremec TKO 5-speed or a Tremec T56 6-speed.
Old Jan 31, 2007 | 12:40 AM
park8b156's Avatar
Car: 91 Camaro RS
Transmission: s
Axle/Gears: stock
Yeah its a manual
Oh I forgot I need to know what kind of clutch that would go with you Ideas for the trany thanks for your ideas.
Old Feb 3, 2007 | 04:18 AM
Pat Hall's Avatar
I'd recommend a Ram Powergrip, Spec Stage 2 or 3, or at least a Centerforce Dual Friction. Keep in mind that if you decide to go with a T56, good clutches are ridiculously expensive. If you decide on a Tremec TKO, they use the same 26 spline clutch that the factory T5's do, so they're quite a bit cheaper.
Old Feb 4, 2007 | 01:46 AM
mightymouseman's Avatar
Car: used to have red 1991 camaro RS
Engine: with 305 TBI
Transmission: Borg Warner T-5
Axle/Gears: and 3.08 open 10 bolt
i had a t5 in my old 91. i think myself quite fortunate to not have grenaded it even behing a lowly 305. clutches were a real PITA though.
Old Feb 4, 2007 | 01:50 AM
Boosted_SS's Avatar
Car: Cobalt SS/SC and 88 IROCZ
Engine: 383 TPI
Axle/Gears: 3.73 Eaton Posi
my friend does transmissions for GM and he says if you race your car you will regret the t-56 but if you are looking for gas mileage the t-56 will be your best friend. he says the gears are very close together and it is really really easy to miss a gear when racing with a t-56. if you are at 450hp you may need to look into beefing up a t56 or a t5
camaro11j
Sep 19, 2018 08:49 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
