TCC not working correctly?
Old Feb 1, 2007 | 09:17 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
The lockup does engage but it only drops my rpms by a 100. Is this normal? I wired up the two ports on the little plug under the dash, and can see the rpms drop when I hit the switch. I know the car is shifting into fourth. Doing about 110 mph I'm at 4k rpms. The drivetrain is stock from a 91 305tbi.
Old Feb 2, 2007 | 01:35 AM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
The lockup part of the trans will only drop the rpms a couple hundred RPM it 's a normal condition .. The Tacks in the cars aren't too accurate so I wouldent worry too much..
Ghettobird52
Jul 5, 2024 11:18 PM
jklein337
Sep 19, 2018 06:23 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Linson
Aug 21, 2015 02:12 PM
Vintageracer
Aug 11, 2015 08:13 PM
