need info on 4th gen 5 speed swap to 3rd gen
Old Feb 3, 2007 | 12:03 PM
MartinD's Avatar
picked up nice 5 speed froma 95 camaro and want to put it inmy 86.looks alot alike EXCEPT my original bellhousing wont bolt that that transmission.the pattern isnt even close.do i have to get one froma 4th gen and then is the hydraulic clutch the same?
Old Feb 4, 2007 | 08:20 PM
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
If you picked up a fourth gen 5 speed, it will only work behind a V6 car. All fourth gen V8's came with a manual tranny came with a BW T56 - 6 speed.
The five speeds were only in the 3.4 liter V6 cars.
Old Feb 7, 2007 | 06:52 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Nope! 3800s had um too. Cause I got one, I just pulled.
Old Mar 30, 2007 | 05:10 PM
boostedv6's Avatar
Re: need info on 4th gen 5 speed swap to 3rd gen
So a 4th gen 5 speed will bolt straight into a v6 third gen? Do you need a custom crossmember and driveshaft? Is there anything else you have to swap?
InfinityShade
Aug 22, 2015 08:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
