Stupid Question about Posi
Old Feb 5, 2007 | 07:54 AM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
What exactly does posi mean, is il like limited slip or am i completely wrong?
Old Feb 5, 2007 | 08:43 AM
smartman__007's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
Posi is a generic Slang term we use for Limited Slip Differentials. There are different kinds with Limited Slip being the most popular. Limited slip uses clutches and does what the name implies. It only allows limited slippage of the tire with the least traction???? making it many times better than an open differential. It's popular because it's road worthy and you have no idea it's there until you look at the black marks you just left.
Then there are lockers that actually mechanically lock the two axles together when one tire is spinning considerably faster than the other. Most lockers are noisy and the stock GM units almost always get destroyed with high HP and TQ applications. They also don't like to take turns sometimes, locking, unlocking and clanking when turning. The whole reason many cars have an open differential is because of the difference in tire speeds when turning. Not good for power transfer but when you're going to pick up Timmy from school, having both tires spinning doesn't mean much. Hope this answers your question and I am not ENTIRELY sure on the exact limited slip whether it's the tire with the least or most traction.
Cleotiz
Jan 6, 2018 08:56 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
mcgarnicle
Aug 12, 2015 04:58 PM
