LT1/T56 swap
Old Feb 8, 2007 | 02:04 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
LT1/T56 swap
Right now I have the LT1 with a 700R4. I have all the parts to do the T56 swap but I wanted to confirm everything. Is it better use the 3rd or 4th gen pedals? I have access to both and that is really the only thing I am teetering on right now. Also, where can I get the pigtails for the reverse lights, reverse lockout, and clutch start switch? I can't find those anywhere. Here is a list of what I have so far:
1.) Spec stage 1 clutch kit
2.) GM hydraulic assy
3.) Spohn x-member
4.) 3rd gen pedal assy (4th gen is easily obtainable)
5.) pilot bushing
Is there anything I am missing?
Old Feb 8, 2007 | 02:21 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
The pedals from the third gen are fine. most people use them in the conversion anyway, so use what you have and save some valuable money. Here is a site to help you on your way. http://www.skulte.com/T56.html it has step by step info of what you need to do. As for the pig tails, I am not certian, but they should be the same for any T5 third gen as well. look up anybody who is parting a 5 speed third gen in the classifieds here and see if you can get pics of the tranny harness.
Cheers!!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
