Excessively stiff clutch pedal?
Old Feb 15, 2007 | 12:30 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
The clutch pedal on my '85 Z28 is extremely stiff (ie, hard to push in). Yesterday the bushing that holds the master cylinder push rod to the clutch pedal broke causing the rod to fall off the pedal thus making it impossible to shift. I bought a new bushing and it broke after pushing the clutch in about 5 times. Bought another and the same thing happened. It seems that there is so much resistance against the pedal that the push rod twists sideways upon being pressed in. What would cause this? Conversely, the clutch pedal on my '89 RS is extremely soft requiring almost no effort to push in, but it shifts perfectly.
Old Feb 17, 2007 | 08:14 PM
RSFreak's Avatar
Anybody?
Old Mar 1, 2007 | 03:48 PM
Gymbeau's Avatar
I don't have any insight to your problem. I have a similar problem in that the clutch push rod has come off of the pedal. Where did you get the bushing? Does the bushing go on the pedal or on the push rod? I don't suppose you have any pictures, do you?
It is on my son's car and he is 1300 miles away at college. I'm trying to help him out.
Old Mar 20, 2007 | 02:04 AM
RSFreak's Avatar
Just revisiting this thread to see if anybody responded.
Gymbeau: No I don't have any pictures. The bushing goes on the pedal and the push rod slips over it. The bushing is supposed to hold the push rod in place but mine isn't. I'm totally at a loss as to what to do. I guess I'm gonna have to pull the master cylinder and see if it is stuck or binding and check the clutch fork to see if it is binding or hung up on something.
Old Mar 20, 2007 | 05:46 AM
Gymbeau's Avatar
We bought the retaining clip that goes on the brake pedal. It is metal and it is a separate piece from the bushing. If your pedal is that stiff, I would definitely check for binding and such. Does the clutch even disengage?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
