th 350 swap
Old Feb 15, 2007 | 11:38 PM
ben r's Avatar
th 350 swap
what do i have to do to put a th 350 in my 89 rs
Old Feb 16, 2007 | 06:46 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Search for more details, but you have to remove the stock tranny first.
Bolt on a B&M torque arm adapter to the new TH350 (make sure you get a long tailshaft version (9" IIRC). Reuse your stock tranny crossmember, and 700r4 driveshaft. Install it all, and hook your speedo cable to the new tranny. BUy an adjustable detent cable for downshifts....I dont use one, since i always downshift manually. Hardest part will be the dipstick. They dont seem to fit right, best bet is to save headachse and buy a Lokar flexible, it makes the job easy and looks awesome! Oh, and you will have to run a vaccuum line to the modulator (definately bends a metal line, dont use rubber for more than 4" on either end.)
Old Feb 18, 2007 | 01:37 PM
ben r's Avatar
my th 350 is a short shaft will it fit or do i have to get 1 that has a long shaft
Old Feb 19, 2007 | 09:39 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
The short shaft will work with a driveshaft from an 82 with a 200c tranny i think. Its a three speed tranny. The 700r4 shaft will be too short. You can buy an adapter kit, not the torque arm kit, that will extend your tranny tailshaft housing and output shaft to work with the 700r4 driveshaft and tailshaft (maintaining your tq arm mount). Search for techpak switchkit or go to this link:
http://www.bulkpart.com/Merchant2/me...roduct_Count=1
If you do some searching online, you will find the distributers for this product and give them calls to get a cheaper price. If i recall i had one quote me $99 plus shipping. Although i went with a long tailshaft model and the B&M torque are kit.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
