Putting in TCI 4th gear lockup harness.
Old Feb 21, 2007 | 09:54 PM
183berlinetta's Avatar
aight so im putting the 4th gear lockup harness on my 700r4. ive taken everything off of the engine/car that runs off of the computer. its fully mechanical. now, the question is. with me not using my computer and putting on the wiring harness do i need to use a lock-up or non lock-up converter. (is the lockup controlled by the computer?) i will be driving this car on the street, not a race car.
Old Feb 21, 2007 | 11:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You still need a lock-up converter.
Old Feb 22, 2007 | 07:05 PM
can i use a nonlockup
a lockup needs the ecm to control it dosent it. so if im running without my ecm i need to use a non lockup dont i. please explain
Old Feb 22, 2007 | 07:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, the TCI wiring harness you're going to put in will control the lockup.
Old Feb 22, 2007 | 07:18 PM
aight i just want to get it right.
but it says: " With the 376600 installed properly your ECM will no longer interface with the transmission. DO NOT ATTEMPT TO PLUG THE OEM WIRING HARNESS FROM YOUR COMPUTER INTO THE TRANSMISSION WITH THE KIT INSTALLED! IT IS NOT COMPATIBLE. the ECM will continue to control your torque cnoverter lockup."
Old Feb 22, 2007 | 07:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's right, you'll need to do some rewiring when you install the kit.
Old Feb 22, 2007 | 07:29 PM
man i am now offically confused. the only wiring i know how to do is what is on the paper (instructions) in front of me. where can i go for help on this
Old Feb 22, 2007 | 07:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's in the wiring diagram in Figure 4. You can either run new wires, or you can modify the factory harness.
Old Feb 22, 2007 | 07:38 PM
so if i just do what the instructions say i can still use my lockup converter even if ive ripped my computer out completely (thats what ive done)
Old Feb 22, 2007 | 07:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, the whole point of the kit is to control a lockup converter without the ECM.
Old Feb 22, 2007 | 07:52 PM
i thought it was in order to keep my 4th gear (overdrive). and one more question and ill stop being a pest. can i stop with step 5 or is it necessary to continue on to step 6. (getting more control over the tcc.)
Old Feb 22, 2007 | 08:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll still have 4th without the kit. The shifting of the gears is controlled hydraulically by the valvebody of the transmission, with no input at all from the ECM. Without the torque converter clutch locking up while cruising in 4th gear though, the transmission will run hot and its lifespan will be limited.
Are you talking about the extra dash-mounted switch on the green wire? You don't need to do that if you don't want to. It would be easy enough to add later anyway.
Reddeath210
Oct 6, 2015 08:20 AM
jbd1969
Aug 17, 2015 07:06 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
