Flywheel question
Car: 1988 Mazda RX7
Engine: 350 L98
Axle/Gears: 4.11
Flywheel question
Is the T5 flywheel interchangable with a T56 flywheel and vice versa?
I am looking to couple a manual gearbox to my TPI 5.7 and need to find a flywheel & transmission.
I have a good deal on an LT1 flywheel, but want to make sure it will work with a T5 if I find a good deal on one of them before I find a good lead on a T56.
Thanks.
Thanks.
No, they are not the same.
If your 350 is the stock one for your car, i.e. 86-up, then a flywheel from 86-92 305 5-speed is what you need. Whenever you go to a T-56, you'll need the right flywheel for that; the stock LT1 one will work.
BlackphantomZ28
Aug 31, 2015 10:29 AM
