Torque convertor
Old Mar 1, 2007 | 01:21 PM
whatsup's Avatar
Torque convertor
Here is a picture of a recent purchase I made off of another board. Its suppose to be a 3500-3800 convertor for a turbo 350. Yes I bought used...the person assured me it was in good shape and the car launched really hard that it came out of. As you can see by the picture something is wrong with it. I have no idea how convertors operate or what they look like inside. The piece you see is basically round and floating around in the front of the convertor. Any thoughts on what is is? I'm deffinately not going to put in front of my brand new tranny....hopefully the seller will give me a refund ( says he will ). But just curious on thoughts about the piece in there? Thanks.
Old Mar 1, 2007 | 02:26 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
looks like a piece of metal is laying in there
where did it come from ?
just remove it ?
run it by a tranny shop real quick and get an opinion ?
thats wierd.
lol
Old Mar 1, 2007 | 03:00 PM
whatsup's Avatar
Cant take it out unless I were to cut it out. It is completely circular. I slid it over with a pencil so I could get a good photo of it....otherwise it is just floating in there. Had to come loose from inside the convertor some where looks like a shim or thrust washer....something along that line.
Old Mar 1, 2007 | 03:29 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
I'd say it looks like a thrust washer . I'd also say sorry the converter's junk .
Old Mar 2, 2007 | 02:43 AM
Pro Built Automatics's Avatar
Get your money back!!!
Old Mar 5, 2007 | 11:43 AM
whatsup's Avatar
Yeah I'd like to...its a six hour drive though from where I live...looks like a $150 lesson.
Old Mar 8, 2007 | 08:07 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Looks like a thrust washer from inbetween the impeller and turbine inside the converter.. to be honest the 150 dollor mistake probably just saved you 1500 for a trans rebuild. putting a used converter infront of a new trans is a terrible idea, you can't completly clean a converter without cutting it open and all the fluid from the converter goes right into the cooler then into the trans and with new trans fluid being such a good detergent it woudl have probably cloged the cooler and cooked your trans... good luck man
Old Mar 8, 2007 | 08:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
have him send you a check back.
Old Mar 9, 2007 | 03:30 AM
EvilCartman's Avatar
Car: '82 Z28
Have a place that does converters open it up and repair it.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
