manual valve body
Old Mar 3, 2007 | 09:23 PM
Gramps's Avatar
Car: 87 Camaro IROC
manual valve body
is it possible to have my 700R4 with a manual valve body so when i put it in Overdrive, the automatic part takes over, but when i want to, i can select the gears manually (like a manual valve body).
see...the reason i ask is because i wanna take my maro to the track once in a while, but i dont wanna have to shift gears every time i wanna get there. is it possible to have automatic on the streets and then manual at the track?
any insight would be great.
Gramps
Old Mar 3, 2007 | 10:20 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
EDIT: ok nevermind.. that was for fords
Old Mar 4, 2007 | 01:18 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not sure if one is available for the 700R4 but I had a similar one in a TH400 I used to use. If in D, it would shift like a normal automatic but I could start in first and hold it as long as I wanted until I decided to shift to second. Same thing for second gear allowing manual shifting through the gears.
Old Mar 4, 2007 | 07:34 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The transgo 700 2&3 shift kit allows for full manual control and retains the full auto shifting also.
Old Mar 4, 2007 | 08:42 AM
fin170703's Avatar
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
The TCI streetfight transmission i've just brought has manual valve body yet still allows for auto shifting. is that what you mean ??
Old Mar 4, 2007 | 03:16 PM
Gramps's Avatar
Car: 87 Camaro IROC
hey floorguy, do you have a part number for that transgo shiftkit? im looking online but i dont want to order the wrong one.
Old Mar 4, 2007 | 05:04 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Transgo 700 2&3
Old Mar 4, 2007 | 05:23 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
I thought that the Hurst (or B&M Cant rember) was for.
Dual gate shifter, meant you could run it in stock gears, or flip the gate and put it into race mode where you have to shift it, so it doesnt overshift.
Old Mar 4, 2007 | 08:31 PM
Gramps's Avatar
Car: 87 Camaro IROC
ya thats true sheldon, but you need to have a manual valve body for it to work.
Old Mar 5, 2007 | 03:35 AM
84CamaroSS's Avatar
Car: 1984 Camaro
Engine: 350 bored .30 over
Transmission: TCI 700-R4
Axle/Gears: Stock 3.23 i think
Yeah i have the same thing this is what he is talking about. Its a manual/automatic valve body put it in 2nd, drive, or Overdrive and it will automaticly shift to theat gear up hold it untill shifted higher. Or you can shift it your self you know whatever you like.
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
Out-Cast
Aug 17, 2015 10:57 AM
