one more tv cable issue: slack
Old Mar 4, 2007 | 02:10 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
even with it set all the way back or no matter how many times it clicks.. there is a bit of slack on the cable i can pull it out like an inch. Could this be causing my car to not shift into 3rd? or am i looking at a rebuild
Old Mar 4, 2007 | 06:45 AM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
justin you can do a simple set up. if you talking about the cable near the throttle body. push the tap in and slide it all the way back, go in the car with the car off and push the gas pedal all the way down. cable should click. this will give you a rough area that you should be around, going to a shop to check the pressures and have them fine tune it is what i did.
Old Mar 5, 2007 | 03:59 AM
Pat Hall's Avatar
Hey Justin, check out 86T/A's post on this board titled 700r4+3.73+sonnax spring. There's spring kit you can buy that takes up the additional slack in the TV cable. I got mine for $9 shipped from patc raptor's ebay store.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
ironbmt
Sep 27, 2015 06:00 AM
