Rear end question
Old Mar 8, 2007 | 12:08 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Rear end question
Does anyone know which spline count rear end they used in 89? my rear end is pretty much shot, the bearings are whirring like crazy, and the posi clutches let go a week ago, so time for a rebuild. i also need to know if since my car came with a 2.73 posi which should be a series 2 carrier if i have to get my auburn pro series posi as the same one or can i switch to 3 series? thanx
Old Mar 8, 2007 | 12:29 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
1989 was the change over year from 26 to 28 splines. Some rears such as the 2:73 may have the 26. Only sure way is to pull one and find out for sure. Nothing else is going help so don't order parts until you are sure.
Old Mar 8, 2007 | 02:13 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
88 was the year of 28 spline change
we cant guess what ratio is in your car
pull the cover or get the code off the pass side axle tube
good luck
Old Mar 8, 2007 | 08:12 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
If i get the code off the axle tube where can i find out what it means? i know my car has a 2.73 posi in it cuz i decifered the RPO code for it. GU2 and G80.
Old Mar 9, 2007 | 04:33 AM
Pat Hall's Avatar
You answered your own question on the ratio as long as you have your original rear. GU2=2.73, G80=Posi. The original rear from my 89 RS was 2.73 also, and it had 26 spline axles. I would say probably 80-90 percent of the 89's had the 26 spline axle because they didn't switch to 28 spline until almost the end of that year's production. But like the other guy said, the only way to know for sure is to pull an axle and count the splines. On your other question, yes, you need to order your new posi carrier in the 3 series to run better gears. 2 series=2.73 and 3.08, 3 series=3.23, 3.42, and 3.73. All axle housings are identical whether you have a 2 or 3 series carrier, so either series carrier will fit just fine in your axle housing.
Old Mar 10, 2007 | 06:39 AM
ede's Avatar
ede
89 was the change over year and most were 26 with only a few at the end of the 89 run being 28. the spline count on the axles isn't a big deal. get the carrier you want or need and buy axels to match it.
Old Mar 10, 2007 | 09:14 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
OK well i ordered my gears and posi. Has anyone ever did a comparision on how much faster switching from 2.73's to 3.42's are?. just curious how much faster in the 1/4 my car will be. i was thinking .2-.5 faster E.T's
Old Mar 16, 2007 | 08:26 AM
bolandmi's Avatar
Anyone have a list of the RPO's for the differen't available rear-end gears?
Old Mar 16, 2007 | 08:49 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
hum well i guess the changeover year depended on the vehicle model because i see some models were 26in 88 and some were 26 til 89
http://www.ring-pinion.com/PartsList...b-Differential
for RPo axle ratio codes do a google
there are lots of pages out there listing them,
theres a billion of them
heres a partial listing
GU2 2:73 ratio
GU4 3:08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio
GT5 4:10 ratio
GQ1 Open Differential Rear Axle
G80 GOV-LOC Rear Axle
and another:
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 -- AXLE REAR, 4.56 RATIO
and there were billions more such as 2.77 and 3.27 and 2.41 and 2.56 and 2.21 and 3.40 and so on that GM has had over the years
Old Mar 16, 2007 | 12:53 PM
DJP87Z28's Avatar
GU2 2:73 ratio
GU4 3:08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio
GT5 4:10 ratio
and another:
A lot of mis-information you posted with regards to 3rd Gen models only.
Old Mar 16, 2007 | 07:25 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Thanxs for the input guys but this post can be deleted. My rear end is done now i just gotta wait for the weather to break to go drive it.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
