Swapping gears and adding a posi to a differential
Old Mar 11, 2007 | 02:12 PM
Theman0188's Avatar
Car: 76 Corvette Stingray
Transmission: TH350
Axle/Gears: Stock
I have a 92 firebird and a non running 89 formula 350. I want to put the posi unit and the gears ( I believe 3.42s) from the formula 350 in my other rear end. Everything is still stock. I dont know if one is a 9 bolt and the other a 10 bolt, one a 26 spline, the other a 28 spline. Needless to say i need some answers. Are they different, and can I exchange them?
Old Mar 11, 2007 | 07:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The '89 should have a 9-bolt, and if its a single cat car, it will have 2.77 gears, and if its a dual cat car it will have 3.27 gears.
Its basically a bolt-in, but the brake lines might not match up.
Old Mar 11, 2007 | 07:17 PM
The 89 should have a 9-bolt, the 92 will have a 10-bolt. NOTHING WHATSOEVER will interchange inside them if that is the case.
You could swap the entire rear over, but not the carrier and gears from one housing to the other.
To tell if they're a 9-bolt or a 10-bolt, count the bolts. If there's 9, it's a {drum roll please} 9-bolt. If there's 10, I'll let you figure out what it is.
Old Mar 11, 2007 | 11:25 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
well the 89 rear axle is bent.. I forgot to add that earlier.. so I guess that idea fell through, but thanks for your info.
Old Mar 12, 2007 | 03:11 AM
ede's Avatar
ede
axles are replacable
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
