Rear End swap questions
Old Mar 12, 2007 | 01:23 PM
WhiteDragon's Avatar
Ok.....I know this probably has been asked millions of times but.....ya I tried the search and found nothing......I did find something by Coop91RS how ever if at all possible I would like some pics of someone doing this.
I realize I could figure out how to do it myself but I have some major time constraints (one week and only in the morning. Im going to school to be a mechanic and the camaro needs to be gone by Friday and we only get shop time in the morning.) Having said that I would love some time savers and just general help with this swap.
Any help would be greatly appreciated.
Oh and its an 1984 Camaro, the rear end is stock from that year and I'm changing it with a 292 posi. If you need any other info let me know.
Old Mar 12, 2007 | 01:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What do you want to know?
You have an '84 camaro, and you want to swap in a 2.92 posi complete rear end from a ...? what vehicle?
Or just the gears and posi?
2.92 doesn't sound right, so fill in the blanks here.
Old Mar 13, 2007 | 12:58 AM
its from an 82 camaro (the rear end) and im putting the full rear end (or diff some call it) into my 84 camaro and 2.92 isnt the ratio. its a 292 rear posi rear end. i was wondering if any one had any ways to save some time when u do the swap or perhaps a step by step guide
Old Mar 13, 2007 | 01:03 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
what i do to save time is pull the axles so you can unbolt backing plates then undo bolts for backing plates and hang them out of the way this way you don't need to bleed brakes other than that i can't think of anything else good luck and i hope you don't have any rusty bolts siezed in the rubber bushings
luke
Old Mar 13, 2007 | 09:28 AM
ok thanx man
i sprayed all the bolts with lots of wd 40 before i even started to changed anything so ya...hopefully that makes things easier.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
