MANUAL TO AUTOMATIC SWAP
has anybody done this
does anybody know what parts i will need?
also i was was told that if i was going to convert to automatic i would have to change the posi rear end as well is there truth to this?
thanks guys
thanks guys
No you do not have to change the rear end.
No doubt somebody wanting to go the other way (the usual swap) can supply you with all of the auto stuff they're taking out.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Assuming you're putting a 700R4 in, you'll need the transmission, dipstick, TV cable, torque converter, flexplate, cooler lines, cooler, shifter, shifter mounting brackets, interior console trim, and some sheet metal to patch the hole for the clutch on the firewall, and the hole for the shifter under the console.
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
