th350 questions....
Old Mar 16, 2007 | 01:55 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
th350 questions....
What shifter can be used in a firebird with a th350? are my only options the B&M? or is there a stocker i can used with little modification?
thanks guys....
Old Mar 16, 2007 | 02:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
im confused exactly what you mean but maybe im not actually lol
i think the megashifters work fine
a 700r4 one will work fine but its just that you will have the overdrive spot on it as your 3rd gear spot, and the 1st gear spot on it wont be anything
the cleanest way would be a 200c shifter like the in my 82 and also in the 83 cars, i actually want to get rid of mine and replace it with an '87 700r4 one that i have here from a camaro that i parted out last fall - i have a th350 but i dont care that the shift indicator plate will be wrong it will still work just fine and no one is going to notice, i just like the later shifters better
i offered my 200c shifter and all te parts except the shift plate assembly(mine is broken and there was no interest in any of it at all
so i guess trash can..
good luck
Old Mar 16, 2007 | 03:14 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
ahhh i see, i didnt even think the 700r4 shifter would work, ill have to rip one out of a junker and make my own indicator via photoshop than lol thanks for the help!
Old Mar 16, 2007 | 03:21 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yep just as long as you dont care about not being able to go into the last/bottom position on the shifter :P
once it warms back up out there again after these days of cold and rain that are coming starting tomorrow then im gonna swap my 200c one out for the 700r4 one
good luck
Old Mar 16, 2007 | 04:23 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
thanks boss, good luck to you too
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
