Kickdown Cable on Turbo 350
Old Mar 18, 2007 | 04:39 PM
irocz286's Avatar
Car: 1986 Camaro IROC-Z
Engine: 355ci, AFR Eliminator Heads etc...
Transmission: 700R4 Woooorked
Axle/Gears: 3:42 with Eaton LSD
I have a Turbo 350 in my 86 camaro and I want to be able to get right on it in 3rd and not have it downshift. If I disconnect my kickdown cable will this do anything catastrophic to my transmission? Thanks, Johnny
Old Mar 18, 2007 | 05:01 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It wont hurt it.
Unlike the 700R4/4l60, ect... which use a TV cable to adjust shift points and line pressures according to throttle position, the th350/400s use a detent cable for downshifting only.
Old Mar 18, 2007 | 05:18 PM
irocz286's Avatar
Ok, yea I know from personal experience what not having the cable hooked up on a 700r4 will do..Just didn't want the same thing to happen to this one. Thanks for the info
Old Mar 18, 2007 | 05:47 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i ahve read and been told that the kick down cable ont he 350 trannies controls line pressure
increases for higher rpm shifts
makes sense to me
good luck
Old Mar 18, 2007 | 06:00 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
No, is only there for triggering kickdowns on the Th350/th400s.
On the 200-4r and 700r4 trannys it increases line pressure with throttle amongst other things. That is why they burn up so easy with it disconnected, no pressure + high hp = goodbye tranny!
Frozer!!!
Jan 19, 2024 04:55 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
