thirdgen suspension brackets for 9" ford
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
is there someone that sells a weld on bracket kit for 9" rears? ive been looking but i cant find anyone. also if there is not how have you guys made the torque arm bracket? did you intergrate into the 3rd member bolts somewhere?
thanks
kent
thanks
kent
how much did it run? what about the lca, panhard and shock mount brackets?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think it was $150 for the TA mounting bracket. All the other brackets come off a donor 10 bolt.
how does the torque arm bracket mount? does it bolt to the 3rd member. im trying to figure out what i need to get to do the swap
Car: 87 IROC L98
The bracket bolts to some very thick tubes that are welded to the housing in 3 places.
What 9" housing are you planning on swapping in? Is it the same width as the third gen housing? What about the axle bolt pattern, brakes etc?
Normally by the time you're done trying to do a fabrication swap, you can buy a bolt in housing for less. You can pick up a housing assembly which includes the bolt in housing and axles for about $1000. You supply the center section and brakes.
It's when you buy a complete, bolt, in, ready to run differential that it can cost close to $2500.
well i got a complete 9" from a buddy for 100 bucks. open diff. well it came out of a station wagon origionally, then it was cut to fit a ranger. depending on how the widths compare (lenth of 9", to my rearend) i was going to keep the stock axles and redrill them to my bolt pattern. i was going to get a ford tru track 3rd member with gears and use that. im going to use pretty much stock parts because they wont break for what im going to use it for. so depending on how the width compares im going to have go different routes. use this rear or get one aftermarket.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
the moser bolt in houseing for thirdgens is only 800 or so with tq arm mount from moser, get some axles, gears, posi/spool, install kit and the stock thirdmember off the 9" you already have and you got a complete 9" for around $1500, shop around and get parts used and cut the costs even more. so far i got 460 into my houseing (bought it off a member here) same housing as listed above, i got a third member for 150 bucks, brakes were given to me for free (lt1 rear disks) and the rest of the parts i figure around 600, so 1250 and i got me a nice 9"...not to shabby
wow 460? thats a deal! i need to find something like that. did you go to a tubular torque arm when you installed the 9"?
Terrell351
Jun 13, 2021 01:13 PM
