168 or 153 tooth flexplate
Old Mar 17, 2007 | 02:14 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
im getting ready to start ordering parts for my automatic swap. does it really matter if i use a 168 or 153 tooth flexplate. i know i have to check to make sure which one the starter works with. but i think the engine block has 2 set of starter holes. is one better than the other. the car had a manual so i know that that starter should work with a 153 tooth flexplate. any help would be great. thanks alot
Old Mar 17, 2007 | 04:21 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
no it doesnt really matter
but use the right one for the starter nose you have
this what does matter
good luck
Old Mar 17, 2007 | 07:47 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have a brand new GM 153 tooth flex plate that I took of my ZZ383 crate motor. If your interested in it $30.00 + shipping.
Send me a PM if interested.
Old Mar 18, 2007 | 01:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 153 tooth is smaller and lighter, and its what our cars came with, so use that one.
Old Mar 18, 2007 | 02:02 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
sure its probably lighter but not going to make any difference to the driver or anyone else
im using 168 in mine
just gotta make sure the right starter nose is there is all
good luck
Old Mar 18, 2007 | 02:17 PM
Car: 84 camaro Z28
Engine: 434sbc
my starter doesnt have a nose. it is a jegs gear reduction mini starter. there add says it is for 153-168 tooth flexplate. ill just get a 153 tooth flexplate.
Old Mar 18, 2007 | 02:52 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Just make sure you get the right one with the right balance. Probally externally balanced...
Old Mar 18, 2007 | 02:56 PM
Car: 84 camaro Z28
Engine: 434sbc
yeah my motor is all internally balanced, so that means i should get an internally balanced flexplate right?
Old Mar 18, 2007 | 06:58 PM
Comp788's Avatar
Yes. If your motor is internally balanced you need a flexplate without a weight.
Old Mar 18, 2007 | 10:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
one piece rms engines are "internally balanced" but the flexplate still has that bat wing shaped weight on one end. FYI.
codeysabatini
Nov 10, 2015 04:07 PM
gord327
Oct 3, 2015 01:25 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
roysatikas
Sep 7, 2015 08:08 PM
