is this trans cooler to overkill for me
Old Mar 20, 2007 | 05:57 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
im getting ready to setup my car for my automatic trans. im looking for trans coolers. i was looking at this one but i think it might be alittle to overkill.
http://www.jegs.com/webapp/wcs/store...51118_-1_10535
my rad does not have a trans cooler built into it. would i be better off with just a regular trans cooler or should i get the one above. let me know what you think
Old Mar 20, 2007 | 07:49 PM
joshmack's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 377: comp 10.5:1
Transmission: 350 turbo- 8 inch Coan
Axle/Gears: 10 bolt-373
Re: is this trans cooler to overkill for me
i have one and it works great. 350 turbo 8inch coan 4000+ stall street car, cooler is great if you have a high stall and need it. great car man. please please tell me what you are running in the quater and post some slips if you have them the car looks great.
my car is under northeast page2 joshmack poll cage or not tell me what you think
Old Mar 20, 2007 | 10:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
can't go wrong with those...I run the largest TCI cooler on mine with no fan, but this year I'll add the temp guage and probably run a fan on mine as well.
Old Mar 20, 2007 | 10:35 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I've got an old style aftermarket barb fitting A/C condensor for mine.
Old Mar 20, 2007 | 11:35 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
There's no such thing as overkill for a trans cooler.
The cooler, the better!!
The bigger, the cooler!!
Old Mar 21, 2007 | 05:59 AM
Car: 84 camaro Z28
Engine: 434sbc
thanks alot guys. ill order the bigger one with the fan on it tonight. is there a wiring kit that i should get with it. do i need to install a relay like a coolant fan.
joshmack: i do have time for the car, but they are alittle imbarrassing. thats why im putting in the automatic. ill have new times by the end of the spring.
Old Mar 21, 2007 | 12:15 PM
xpndbl3's Avatar
Car: 1984 Z28
If the kit doesn't come with a relay, you can always buy one from your local parts store. I like the M-55 relay that is a GP sorenson or however it's spelled from my local stores, the relay even has a mounting tab with hole for a screw on the top of the relay.
deracer
Apr 11, 2016 12:04 AM
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
