Trans Problem
Car: 71 camaro, and also a 91 camaro
Engine: 383 stroker
Transmission: t5
Axle/Gears: 3:73 strange axle
Trans Problem
just recently bought a new flywheel, clutch, pressure plate, throw out bearing. and now it is very hard to put into gear, i have bled the daylights out of the hydro clutch, and still not working properly.... the car will not get into rev without grinding gears.... can any one help me with this prob???? any help is highly appreciated...
Re: Tran Problem
Which way did you put the fork into the throwout?
Reverse will always grind, if you don't put it into a forward gear first. It has no synchro. That part is normal, up to a point.
Engine: 383 stroker
Transmission: t5
Re: Tran Problem
i cant remember really. when the car is off the gears go in so smoothly, when the car is on it is very difficult to place into any gear. when it is rolling it is fairly simple, but def not the way it should be.... when i place it to rev, it is extremely dif, and annoying sounds occur, so i turn off the car and start it into rev with no problem.... thank you for your help
Re: Tran Problem
The mis-assembly in the pic is the usual cause of that. That, and failure to replace the pilot bushing / bearing, which is conspicuous by its absence from your list of replaced parts.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
