4l60e overdrive issue???
Old Mar 24, 2007 | 12:19 AM
01sesedan's Avatar
Just installed the transmission and now I'm taking it out for a test drive.
This is in a 94 Suburban. I noticed that the rpm's would not drop much once I get going. Example, while driving on i75 at around 65 mph the rpm's were around 2300 to 2400 rpm. Seems kind of high. When I apply the brakes slightly the rpm's would go increase about 200. Tires size is 265/70/17(i believe) with a 3.42 rear, not sure if this helps.
I did install a transgo hd2 shift kit, not sure if I missed a step. I'm planning on dropping the pan and remove the valvebody. Maybe the valvebody gasket shifted on me when putting it back together. BTW, with the shift kit installed, I thought it would shift faster and a little firmer. At this time, it seems close to stock.
What do you thing I should check out.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
84 TA NV
Sep 6, 2015 08:02 PM
IROCZ1989
Sep 4, 2015 11:54 AM
