how to change from open rear to posi insides
Old Mar 25, 2007 | 12:42 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
so right now i have a 2.73 open diff rear end with the drum brakes on my 1989 firebird. things is i want a posi and dont want to change the whole rear some i have some 3.42 gears and a posi unit coming to me suppossedly from a 91 or 92 camaro. what would i need to make this work? and if i dont change the speedo gear how off will the speedometer be for this change?
Old Mar 25, 2007 | 06:58 PM
Engine: LO3
Re: how to change from open rear to posi insides
any help because i plan on doing this this week.
Old Mar 25, 2007 | 08:09 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check your axle shaft spline count. You may 26 and the 91 parts will have 28. If that happens you are going to have a long weekend. Also walking until you put it back together.
Old Mar 25, 2007 | 08:15 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
342/273 = 125 so you'll read that you're going 25% faster than you actually are.
The axles should be the same # of splines. You'll have to make sure you shim the new carrier right so it doesn't whine.
Old Mar 25, 2007 | 08:45 PM
DJP87Z28's Avatar
I would not bet on the splines being the same. 1989 was the change over year and GM had a large inventory of rears were 2:73 open to use up..
Old Mar 25, 2007 | 09:09 PM
305q_ta86's Avatar
Transmission: 5 spd
Oh, I thought they ALL changed. Hm, well yeah then there might be a problem.
and i just realized that i forgot a decimal.. 342/273 = 1.25 not 125, lol. Same end result though..
Old Mar 26, 2007 | 12:50 AM
Engine: LO3
interesting so basically need 28 spline if i dont already have them and shims to line it up? nothing else?
Old Mar 26, 2007 | 03:28 AM
ede's Avatar
ede
there's no shims used to line up the axles. do a search for my user name and sofakingdom and you'll find all you need to know
Old Mar 26, 2007 | 10:33 PM
Engine: LO3
o no i know you dont line the axles up with shims you gotta shim the unit and gears to line up everything so it doesnt whine. i already got the shims that have been laying around.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
