700r4 tranny lines what can I use ?
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I was wondering I anyone uses anything other that steel lines for there transmission. I tried putting in my hedman long tube headers yesterday and the tranny lines are right in the way. And rather then getting new steel lines and have to bend them is there any safe and reliable flex lines out there ?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r4 tranny lines what can I use ?
I've got braided stainless hose for my cooler lines. Reinforced rubber hose would be a lot cheaper, but just as effective.
Car: 1984 z28
Engine: 355
I am I able to pickup the reinforced rubber hose at the local auto parts store and should i use any special hose clamps?
Engine: 383 Carb
Transmission: 4L60
You should be able to get it easily enough, tell them you want transmission cooler hose, or power steering return hose. Regular worm clamps will work fine. The fittings in the rad and the transmission are 5/16" inverted flare, you'll need adapters with hose barbs.
Car: 1984 z28
Engine: 355
Just out of curiosity if I go to the track do you know if I will pass the car check when i race ?
Car: 1987 Firebird
Engine: 355
Ive seen this done on a car, (A-body actually). Would be a little trickier on a F-body to do, but this fellow ran the lines through his frame and exited just before the tranny. This way, he didnt have to worry about any heat getting to them, the rubber was already reinforced, but now it was shielded as well.
"Out of sight and out of mind" i beleive is the best way to describe it. Food for thought!
Engine: 383 Carb
Transmission: 4L60
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
