tranny spline question
Old Mar 26, 2007 | 01:26 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
On a 700r4 from a 91 camaro, is it a 27-spline or 30-spline coming out of the transmission? I counted 27 on mine but just wanted to make sure.
Old Mar 26, 2007 | 06:18 PM
Pro Built Automatics's Avatar
Re: tranny spline question
All 700R4's from mid 1984 are 30 spline. To make sure, measure the diameter of the shaft, it should measure apx. .990". The 27 spline is apx. .890".
Old Mar 27, 2007 | 01:43 AM
Pat Hall's Avatar
Pro Built is correct for the input splines where your converter is, but you stated that you counted the splines on the output shaft, which would be 27 splines like you stated, same as a TH350 or any of the manual trannys.
Old Mar 28, 2007 | 04:26 AM
The TH350 has 30 splines, same for the TH400.
Old Mar 28, 2007 | 07:21 AM
Pat Hall's Avatar
No, he said he counted the splines coming out of the trans (i.e. output shaft/slip yoke), which would be 27 on a TH350, and 32 on a TH400.
Old Mar 28, 2007 | 09:22 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Are you looking for a torque converter or a driveshaft yoke? the output shaft is gonna have 27 splines (for the yoke). You gotta count the splines on the input shaft for matching a torque converter. non lock-up have less splines (27) and lock-up trannies usually have more (30). the "newer" models are usually lock-up (30 spline).
Old Mar 29, 2007 | 06:36 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
all 700r4's are lock-up unless they have been modified. after '84, the only 700's that had 27 splines on the input were the v-6 models. all v-8 had 30 spline.
Genopsyde
Oct 7, 2015 08:35 PM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
