tv cable help needed
Old Mar 27, 2007 | 12:52 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
im having a problem with my tranny shifting hard and bein held back... im wondering if its the tv cable.... how do i adjust it?
Old Mar 27, 2007 | 01:17 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: tv cable help needed
take your throttle linkange and open it as much as you can. sounds like your tv cable is in to far.
also a search will bring up a more detailed explanation. this has been covered lots of times.
Old Mar 27, 2007 | 03:23 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Its got an auto adjuster on it at the throttle body (on the same mount for the throttle cable). Its like a zip tie, reset it back in...push the pedal to the floor ,to reset it and it will clicky into place.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Aug 8, 2015 03:15 PM
