9" Ford Problems
Old Apr 3, 2007 | 08:07 AM
l1864's Avatar
9" Ford Problems
I have a 1992 Camaro I'd like to put a stronger 9" Ford housing in. Problem is Moser makes a "so called" drop in, but they say it will not work with stock brakes. I just cannot believe the stock drum brakes cannot be made to work. Has anyone else encountered this problem ??? Can't the housing ends be changed - re-drill mounting holes - WHAT has to be done ???
Please help !!!
Old Apr 3, 2007 | 08:12 AM
Re: 9" Ford Problems
Won't stop the truth from being true.
IIRC the problem is that the end of the housing is large enough to where the little weenie drum brakes these cars come with, are too small to wrap around it. Details.
You could do any of several things. Various truck drum systems are available, with larger shoes, that will fit and work; or you could swap over to discs.
Old Apr 3, 2007 | 08:23 AM
l1864's Avatar
Any clue what DOES work ???
Has anyone made this conversion ?
Old Apr 3, 2007 | 08:39 AM
If you just really want drums for some reason, just have Moser put some convenient system on there for you. IIRC one of the common ones is Explorer brakes. Cheap, easy to service (find parts for), entirely adequate for one of these cars. But just ask Moser, they'll be able to tell you what fits and works well and gives good results.
Old Apr 3, 2007 | 03:33 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
LT1 and LS1 brakes will fit, I just bought some LT1 brakes and had moser put on GM housing ends on there for LT1 brakes. No stock 82-92 brakes will fit.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
