Axel swap; Are these the same?
Old Apr 6, 2007 | 12:44 PM
GTA DOO's Avatar
There is alot of info on here for the 9-bolt. Search "drain89" But I need to know if 2nd series carrier AXELS (i.e. tall gears) are interchangeable with 3rd series carriers (i.e. short gears). "All 9-bolts are 28-spline"; in respects of O.D. and Length? Daily Driver is wasting away without axels!!!
To keep it simple... would a factory 2.73 posi 9-botl axel convert to a factory posi 3.27? Both being Borg Warner.
Old Apr 6, 2007 | 12:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Axel swap; Are these the same?
The axles should be the same regardless of which carrier it was.
Old Apr 6, 2007 | 01:32 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just so you know you have RH & LH axle shafts and the lenghts are different.
hectre13
Dec 11, 2023 08:14 AM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
