60ft's with a stick.. post times here..
Old Apr 6, 2007 | 05:23 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
60ft's, 1/8th, 1/4 with a stick.. post times here..
ok guys, i wanna see your 60ft times from ONLY manual cars.. auto's are too easy to hook up.. and if you could, maybe some overall time slips and what tires?? k thanks
mine is horrible:
1.810
7.909
12.416 @ 110
MT ET radials 275/50-15
Old Apr 6, 2007 | 06:52 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Re: 60ft's with a stick.. post times here..
Car is not set up for drag racing but my best 60 ft n/a is 1.793 and best on nitrous is 1.62. The e.t. and mph is in my sig. I hope to get more experience at the strip this year. Not sure how long the 9 bolt will hold up.
Tires were MT ET drag radials 245/50/16.
-Schultzy
Old Apr 6, 2007 | 07:13 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
1.7 60 on street tires
that was as of last year when the car had the manual in it. now im bulding a 700r4 so that i can get some better 60 ft times
Old Apr 6, 2007 | 09:11 PM
5678TA's Avatar
Car: 1984 Trans Am
cool.. keep em coming..
Old Apr 6, 2007 | 09:17 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
what ties, and size were you running?
My best was a 1.60 on 18" street tires.
ET was 13.7@100mph on that run.
Old Apr 7, 2007 | 04:13 AM
5678TA's Avatar
Car: 1984 Trans Am
oh wow.. 1.60? with a 13.7?? amazing.. i guess you just gotta work on the horsepower part.. anyone else want to join in??
Old Apr 7, 2007 | 07:46 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Best is 1.79, 2 weeks ago was:
1.848
8.259 @ 87.86
12.660 @ 114.1
and
1.823
8.219 @ 88.55
12.619 @ 113.89
Using 275/50/15 MT drag radials.
That was with a smoked trac-lok in the 9inch. I've since replaced the clutches in the posi and shimmed them a little tighter. I'm hoping the wornout posi is the reason it won't 1/8 mile.
Old Apr 7, 2007 | 07:59 AM
Car: 84 camaro Z28
Engine: 434sbc
i was running 285 kumos (i forget the exact model). with a 17 wheels. unfortunately on that run i missed a gear so my time was complete crap. all my other runs were around 2.0 range.
Old Apr 7, 2007 | 11:27 AM
Zepher's Avatar
car was rated at 320hp, but weighed 4050 with me in it. 96 3000GT VR4, quick out of the hole and up to the 1/8th but pulls slower to the 1/4 due the AWD drag.
Old Apr 7, 2007 | 05:33 PM
Lo-tec's Avatar
Originally Posted by Zepher
96 3000GT VR4
not really relevant to this post, now is it??
Old Apr 7, 2007 | 05:44 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Yeah, no ****. What are you doing bringing that car in here?
Old Apr 7, 2007 | 08:37 PM
Zepher's Avatar
lol
Ok, best from me in my thirdgen is 1.99 with street tires.
305 LG4 5 speed with a 9.5 1/8th and 14.9 1/4 mile time (my old 86 Trans Am).
My average is 2.0 on street tires.
Old Apr 9, 2007 | 12:35 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
ET Street tires. Times in my sig.
Old Apr 9, 2007 | 03:21 PM
5678TA's Avatar
Car: 1984 Trans Am
1.848
8.259 @ 87.86
12.660 @ 114.1
and
1.823
8.219 @ 88.55
12.619 @ 113.89
hey man, your second run is about my average.. but with a 8.0xx-8.1xx average 1/8th.. your trap speed says you can go faster.. quite a bit faster.. during my best run, i 60ft .01 faster, 1/8th .3 faster, 1/4 .2 faster and trap 3mph slower.. and i believe i run the same mph on the 1/8.. you missing shifts?? you most definitely are not powershifting or even slamming shifts or that would be a LOW 12.. with your mph, your 1/8 should be at least 7.8.. practice banging them gears..
EDIT: it should be 12 FLAT or high 11
Old Apr 9, 2007 | 03:27 PM
5678TA's Avatar
Car: 1984 Trans Am
k, i didnt want to edit that last post 5000 times so here..
what the ___ is a mitsu 3000gt doing being mentioned on a thirdgen f-body forum?? its not an f-body, not a thirdgen, and def. not domestic..
and doesnt have traction problems like us..
Old Apr 9, 2007 | 08:09 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
1.98 60 ft 14.3 @ 95 or so.. I forget exactly not sure if that run is in my pile of timeslips.
That was on an 86 firebird that was a V6 and I threw in a 5.7/ T5 combo, with 3.23 gears. Regular tires ( well worn Eagle GS-C ), and all stock V6 suspension.
Hopefully I can get the 88 back together and make it to the track a few times this year to see what the T56 and 4.10s do.
Old Apr 10, 2007 | 11:25 AM
Lo-tec's Avatar
I know. I'm not powershifting, but not granny shifting either. The second run I dumped it at 5K and it didn't leave that hard. Clutch is ok, so I'm thinking the track is masking some tire slippage with the smoked posi. I'm gonna run it again in the next couple of weeks and see what happens. I'm also gonna play around with shift points; it did pop the rev-limiter in 1st and 2nd on both runs.
Old Apr 18, 2007 | 05:20 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
heres mine on 245/50/16 cheap street tires
60' 2.2
660' 8.9 mph' 82.56
1/4' 13.60 mph' 109
Old Apr 23, 2007 | 01:05 PM
5678TA's Avatar
Car: 1984 Trans Am
k guys, i know theres more out there
Old Apr 24, 2007 | 12:18 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
60' 1.81
1/4 13.89
mph 100.2
thats with bfg g-force t/a drag radial and side stepping the clutch around 5 grand
Old Apr 24, 2007 | 07:29 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
this past weekend i had a decent run granny shifting,trying to save rear and t5
1.64 60ft
7.53 1/8th @ 92.870
26 in m/t et st radial with 20 psi
Old Apr 24, 2007 | 07:41 PM
5678TA's Avatar
Car: 1984 Trans Am
1.64 60ft
7.53 1/8th @ 92.870
Old Apr 24, 2007 | 08:12 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
just a lil street car
Old Apr 26, 2007 | 05:03 PM
Shagwell's Avatar
Car: projects.......
Best 1.66, average between 1.66-1.69. 5K on 2nd yellow, stand on it and side-step the clutch. All on 17" wheels with Nitto DR's.
Old Apr 26, 2007 | 09:37 PM
Lo-tec's Avatar
Can you post your #'s from a timeslip (60, 1/8, 1/4, mph, etc)?
Thanks!
tim
Old Apr 27, 2007 | 12:10 PM
Shagwell's Avatar
The car's been down 2-1/2 years and I've moved 3 times.... I'll try to dig up a slip.
I ran an 11.72 in the high 130mph range at Orlando, but my mph was always lower(and probably more true) at Bradenton - high 120's to low 130's. The car was fairly consistent 11.7X range, 1.6X 60fts. - I believe 1/8 was 7 with a teen.
My info and set-up has been posted many times. One of the biggest keys I've found in suspension tuning for street tires is an aggressive pinion angle and not "airing down" the tires.
Old May 5, 2007 | 12:32 AM
5678TA's Avatar
Car: 1984 Trans Am
alright manual guy dont flake out now.. i know theres more..
Old Jul 16, 2007 | 08:13 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
First trip out to the track with the LS1 and my 60' sucks **** best of 1.96
Best time was a 12.3 with a 1.99 60' at 115mph so I am definitely looking for improvement. Running ET street radials 275/40/17 on fairly heavy Borbet wheels front and back.
I have good suspension too; LCA's w relocation brackets and Spohn adjustable torque arm cross member mounted. I'm hoping more burn out and a trip in the daytime with some heat in the pavement will get me hooking. i was blazing through most of first and getting **** all weight transfer out of the hole. Gonna try more aggressive pinion angle too and hope for better
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
