What / how much fluid?
Old Apr 9, 2007 | 01:44 PM
jjorgensen52's Avatar
I'm just wrapping up an F-body T-5 into an S10 swap, and I've come to the point that I need to fill the tranny with fluid / lube. Anyone have recommendations on what to use, and how much I need? The tranny came out of a 1991 IROZ camaro, but according to the tag it started its life behind an 85 5.0 (# is 1352-072). TIA
Picture or 2
Old Apr 9, 2007 | 08:33 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Re: What / how much fluid?
If it is an 85 tranny it would take gear oil 80-90 should do. If it is an 88 and later it will take ATF . I have had both and run ATF in them with know trouble .Looks good but where is the clutch pedal LoL
Old Apr 10, 2007 | 07:01 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I have an '85 TA w/ a T5 and it was recommended to run ATF in it. The shop said gear lube would be fine, unless it would be run in cold weather.
Old Apr 10, 2007 | 08:20 AM
It did look like it had gear lube in it before it was shipped to me (dry of course) ...
As for the clutch, I haven't filled the system yet so I had the pedal depressed to start the truck and it just stayed down
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
