Clutch Master Cylinder Problem?
Old Apr 9, 2007 | 08:29 PM
white91350rs's Avatar
I have a 91 RS 350 and T-5 Swapped but ne how i was at the stop light the other day and left perfectly normal and when i shifted into second gear the clutch linkage broke off of the pedel so i put a screwdriver thru the linkage and pedel and i could not push the clutch pedel i actually broke the screwdriver and the linkage did not line up with the pedel so has neone else had this problem or can someone throw their two cents in either a master cylinder or a linkage problem i dont think the clutch is blow because the trans grabs gears still if i try to start the car it jerks forward or if the clutch is blow just lookin for any input
Old Apr 17, 2007 | 09:24 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Re: Clutch Master Cylinder Problem?
The same thing happened to my '85 Z a few months ago. The previous owner replaced the clutch last year (he is a good friend of mine so I know he had it done). I posted about it here but no one seemed to know what the problem is. As soon as the weather gets nicer up here I am gonna go out and check the clutch fork to see if it is binding which could result in the hydraulic system being unable move it. I can move the fork by hand on my '89 RS so I assume I should be able to do the same thing on the Z.(?) If I can move it then I will assume that the tranny is fine and check/replace the master and slave cylinders.
Let me know if you figure out the problem.
Old Apr 17, 2007 | 09:37 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
open bleeder screw and re-bleed system. is what happened when the pushrod came off it cause mater cylinder or slave to hydraulic lock. Had this happen on my T/A and couldn't even move the clutch pedal till bleeder screw was opened and bled.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
