New 700r4/TC, Now Shutters...:gocrazy:
Car: 89 camaro rs
Engine: 305 tbi
well it has been a while since i've been on. anyway, i replaced my old tranny an torque convertor. it was a dyno-tested rebuild with a new tc (factory stall- i think about 1800rpm).
ever since i installed this thing, its real rough above ~50mph in 4th gear. i was reading somewhere that around 50mph is when the tc locks up. i also read that the brake pedal has a switch that when pressed (above this lock-up speed) the tc unlocks.
after thats said: if i depress the brake just a hair when it is shuttering it goes away. whats this sound like?
Car: 89 camaro rs
Engine: 305 tbi
Re: New 700r4/TC, Now Shutters...:gocrazy:
forgot to mention that the speed sensor would trip the ses light from time to time before this swap, hasnt happened since then however i wonder if its possible that thats the culprit. thanks.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Sounds like a bad torque converter. I use a small local company that does them for me and my problems went away. Possibly you have a shop by you that could do the same.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
any noises from the TC?
Car: 89 camaro rs
Engine: 305 tbi
Car: 89 camaro rs
Engine: 305 tbi
i know this is old. however ive recently got to where i can/need to drive the maro more. the shuttering is still present. i would put a year's salary on it being the tc not locking up properly.
what can be done?
the shop that repaired and installed my new tranny had me put some heavy-duty, goop of an addative in and nothing. however my 90 day guarantee had expired so they wont touch it w/o cash in hand.
is there a way to disable my tc lockup w/o burning a special chip? maybe a wire i can snip or unplug? because if the lockup is just for economy, i dont care... right now, having to drive in 3rd doesnt make for good mpg.
what can be done?
Car: 89 camaro rs
Engine: 305 tbi
SO... im for now i think i will try to make the tc not lock up. and all i know to do is to trick the tranny into thinking im on the brake all the time... any problems with doing this?
i will do this by hopefully finding the wire going to the brake pedal switch, but not the one for the lights of course. i am hoping there are at least 2 wires present... i dont know what else to do. comment?
Car: 89 camaro rs
Engine: 305 tbi
got a little advice over in the electronics board. i ended up disconnecting the connector with 2 wires on the brake switch. now my tcc doesnt lockup any longer. only downside we've come up with is an increase in tranny temp due to the tc still slipping alittle in OD.<---FYI
