Bellhousing bolts size
Old Apr 12, 2007 | 10:03 PM
183berlinetta's Avatar
i need new bolts to mount my transmission. its a 700r4. does anyone know the actual bolt sizes. (bellhousing, crossmember, and mounts)
Old Apr 14, 2007 | 06:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Bellhousing bolts size
- Tranny to engine - 3/8-16, 1 1/2" long
- cross member - I think those are M8 coarse. They're probably stripped. You can drill them to 3/8", and tap them for 7/16" coarse. If that works, great, mine were too sloppy for that. I dropped in 3/8"-16x1" bolts from the top, and used flange nuts on the underside.
- Mounts? Tranny mount to tranny? I think that's about a 3/8"NCx3/4" or so, with a lock washer, but don't quote me on that one. Tranny mount to cross member should just need a nut, 3/8"NC IIRC.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
383backinblack
Aug 15, 2015 06:36 PM
knight72
Aug 10, 2015 09:32 PM
