rear end question...
Old Apr 13, 2007 | 09:11 AM
camaro350tpi's Avatar
Car: camaro iroc-z 89
Engine: 383 HSR SC MegaSquirt
Transmission: tko 600
Axle/Gears: 9 Inch 3.75
hii have a 89 iroc with a borgwarner rear with a 9bolts "28 spline axel " and i whant to know if i can put a 10bolts torsen posi unit from a 98-2002 t/a or camaro to replace my carrier then i can put a 3.73 gear on it thanks all good day
Old Apr 13, 2007 | 10:30 AM
hatebur2001's Avatar
Car: 1992 RS
Engine: 3.1
Transmission: 5 spd
Re: rear end question...
A 10 Bolt carrier (7.6") from a 1990-2002 axle will not fit in a 9 bolt Borg Warner axle. The BW would need to be swap out with a 1990-1992 28 spline GM 10 bolt.
This link is about brakes, but midway done, there is more info about the 9 bolt BW and 10 bolt GM axles.
https://www.thirdgen.org/forums/brak...ghlight=torsen
Hope this helps.
Old Apr 13, 2007 | 12:13 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
9-bolt & 10-bolt rear axle parts ane NOT INTERCHANGEABLE.....I say again NOTHING
Old Apr 13, 2007 | 08:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The only thing similar between a 10 bolt and a 9 bolt is the mounting hardware how they attach to the car. You might as well be trying to install a 28 spline carrier from a Ford 9". It just won't fit.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
