LT1 cam need new converter?
Old Apr 15, 2007 | 05:08 PM
JustinSane's Avatar
1-when i put a LT1 cam into my 91 tbi 305 camaro should i change the converter to?
2- the car is daily driver with weekends at the strip, if i dont need a converter for that cam, would converter would you suggest just for lowering ET some while keeping lock up feature.
Old Apr 18, 2007 | 11:52 AM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: LT1 cam need new converter?
A converter will always lower the et by putting the car closer to the max torque at launch, as long as you can put the power to the ground. So depending on what cam you put in your car you could gain some performance from a higher stall. I have a stock vette converter that has a little higher of a stall then a stock f body. It has 50,000 miles on it and was in good shape when I removed it.
Old Apr 18, 2007 | 03:53 PM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Yeah, I usually throw the stock convertor in the trash when I get the chance; theyre too 'tight' for real performance use. I would doubt that you need a convertor with a mild cam, but like drperfomance said, it never hurts. If you know what RPM that cam will come in at, then you size the convertor to stall maybe 500 RPM below the start of the powerband, so it puts you right there when you punch it. Stock is something like ~1500 RPM.
Old Apr 19, 2007 | 12:17 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the 2000 rpm stall Corvette / S10 truck stock stall converter is a great inexpensive upgrade for every f-body.
A search for "Corvette converter" should reveal more details.
Old Apr 22, 2007 | 10:39 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
if looking at a budget converter, go with the s10/corvette like kevin said. if ya have a little cash to burn, go with an edge tc like i did.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Aug 29, 2015 09:51 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
