th350 swap finished
Old Apr 15, 2007 | 10:07 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
th350 swap finished
well its been a long process with this build do to weather and work but i finly got my th350 put in and bolter up but int he process i ended up snaping the shifter cable when i hooked up the cable to the trany and testing to make sure everything would shift well when i got into the car and turned the key to test the shifting it wouldnt go into reverse well i added a little pressure and snapped it any idea of why is wouldny of shifted correctly
Old Apr 16, 2007 | 08:56 PM
Engine: 383 stroker
Transmission: th350
Re: th350 swap finished
well i though it was done to find out i put my new flexplate on backwords the starter i did have didnt fit and im hoping that this starter i have will fir the 168 tooth flex plate that came out of a 89 pickup with a 305 will work and sajestions on a good stock starter i can get from orylies or advanced
Old Apr 17, 2007 | 12:54 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
168 tooth takes starter nose with staggered bolt holes
very common
from the 1960s to 1990s
most all were staggered pattern
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
LittleFranks
Sep 17, 2015 12:22 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
