700R4 Lockup Problem
Old Apr 20, 2007 | 07:27 PM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
I was driving 30 miles on the interstate yesterday and noticed that the TCC was unlocking and relocking every few minutes. I did have the A/C on low and it was cycling, can this effect it? I thought all it did was extend a plunger to idle the car a little higher when it engages. On the return trip home, it held steady. Tried turning on the A/C and it was still OK. What things do I look for to chase this problem down? Also if I connect a toggle switch to the ALDL pins for the TCC, does this completely overide the TCC from the computer and brake switch? Which pins are they? A and K?
Old Apr 21, 2007 | 05:56 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: 700R4 Lockup Problem
werll overriding the converter lockup will only reduce your trans' life. were you going up hill or down hill at all? there are a bunch of things that come into account when lockup occurs...braking is one of them...temp is another. its possible that one of those things prevented lockup from ocurring. it could also be how much throddle you were giving...at a certian throddle position, the lockup will disconnect.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
