Kicks out of 1st
Old Apr 21, 2007 | 03:42 PM
MAC25DM's Avatar
Car: 1988 Firebird
Engine: 2.8 liters of fury.
Axle/Gears: Stock
Kicks out of 1st
Anyone have any idea as to why my car will kick out of first. It only does it on takeoff if you slowly ease off the clutch. If you come off quick, it doesn't do it at all, but then it usually "slips" the tires. I was told the linkage might need adjustment. Any clues would help. Thanks
Old Apr 22, 2007 | 01:05 AM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Re: Kicks out of 1st
Nobody can help? I know someone out there has had to have had this problem before.
Old Apr 22, 2007 | 01:16 AM
Teddy Z's Avatar
I had a similar problem before... didn't matter whether I eased out the clutch or not though. Basically sometimes it worked normally, and sometimes it would make a loud BANG and the shifter would damn near break your hand when it smacked your palm. Ended up taking it to a tranny shop and they opened it up to find that the 1st/2nd shifter fork had broke. Luckily the chunk settled in the bottom of the case instead of getting in the gears and chewing er up! Fork was replaced, problem fixed.
Hope ya get er figured out!
Old Apr 22, 2007 | 08:21 PM
MAC25DM's Avatar
Car: 1988 Firebird
Axle/Gears: Stock
Took off my center console and shift boot to do a little looking and found a B&M shifter. Kinda cool to find, plus the shifter was hitting a cover plate in the odd gears, little bit of shaving with the dremel, and it doesn't hit anymore. So hopefully that solves the problem.
Old Apr 22, 2007 | 08:30 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i was just gonna say.. ^^^ gears probably not fully engaging.. that grinding should fix the problem.. my b&m was like that too..
junior419
Apr 7, 2025 11:35 AM
Giocio
Oct 1, 2015 12:20 PM
tattmann
Sep 27, 2015 05:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
