Ugh, hard shifting again but.. not as bad
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
i replaced the clutch the other day and now im running into some issues.
Yes, i put the TOB in correctly(according the CORRECT picture of sofakingdom
) i even have pictures i took of it that i checked when the issue came back, Its not as bad but its there for sure.
Bassicly It grinds in reverse, and i have a clutch disengagement issue.
Ive bled the slave numerous times already, just to find it seems ok then gets worse after a drive of about 10 mins. ( my theory is that i have a internal leaking master cylinder)
Now, it needed a clutch bad before and now i dont smell clutch burnage or feel slippage, which makes me very happy but im kinda frustrated with it doing this again so.
Im ordering a pre bled gm hydraulic setup tomorow, but before doing that is there any other problem you guys would think it would be?
) i even have pictures i took of it that i checked when the issue came back, Its not as bad but its there for sure.Bassicly It grinds in reverse, and i have a clutch disengagement issue.
Last edited by fire350tpi; Apr 21, 2007 at 09:07 PM. Reason: Being parinoid about the TOB but double checked the pics and apprantly its in right
Axle/Gears: 3.23's
Re: Ugh, hard shifting again but.. not as bad
TTT Bedtime
Hope someone can give me some more insight!
Glad the pictures were of service!!
How was the pilot bearing when you took it apart? What did you put back in; a bushing, or a bearing?
Axle/Gears: 3.23's
but like i said before, what makes me think its the slave is that it was working wonderfully, then as the clutch wore in/adhered it started acting up again, making me think it just doesnt have enough throw left
Axle/Gears: 3.23's
Hmm, wierdest thing i took it to a friends house today 10 mins away and it seemed to be ok, not perfect but OK
So i beat on it on the way home and now its finnally back to chirping the tires, but i think theres still something a tad bit "of" Who knows maybe its because my 1-2-3 syncros are going /shrug who knows
Axle/Gears: 3.23's
its back again, lol not like it was oringinally but it is there ( as before)
Now, heres the question.. should i invest in hydraulics ?
