verify 700r4 trani
Old Apr 23, 2007 | 11:32 AM
JohnSjr's Avatar
verify 700r4 trani
im going to be doing a v-6 - v-8 swap and all i can find for info is that in 1988 the 2.8 was mated to the 700r4.
so by all data i can find the 350 i have should mate easily correct guys?
the 350 is an 85' 4bm block.
Old Apr 23, 2007 | 11:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: verify 700r4 trani
No, the bellhousing bolt pattern is different on the V6 and V8 700R4s.
Old Apr 23, 2007 | 12:20 PM
JohnSjr's Avatar
so swap out the bell housing?
or is shaft a different size as well?
Old Apr 23, 2007 | 12:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The bellhousing on a 700R4 isn't removable.
Old Apr 23, 2007 | 01:11 PM
JohnSjr's Avatar
UGH,
not what i wanted to hear... but at least now ill start looking for a 700r4 from a v-8.
thx.
Old Apr 25, 2007 | 02:27 PM
alphamale1906's Avatar
Best of luck with the swap. I am looking for a Gen 3 Camaro, and have been leary of RSs. I figured the v6 to V8 swap may be a little more than I am looking to strap onto. I have a mildly worked 350 from a 70 Camaro that I wanted to stick into the 80's-early 90's body style. However, I figured if I find an original 305/350 car, I can just bolt everything from the original motor onto my block.
BTW, do you know if all IROC's came with the 700R4?
Old Apr 25, 2007 | 02:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All IROCs with automatic transmissions have 700R4s.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
