2.xx gears to 3.27 9 bolt gears
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
well i got some 3.27 gears fianly and a 3 series carrier for my camaro , besides that what else do i need? (seals maybe?) what else would i need to get them in there and going ? , i am oretty sure its just the drop and pop em in but my key word searches never pull up the info i am looking for
Re: 2.xx gears to 3.27 9 bolt gears
You need the same thing everybody else needs when they install a gear set.
It's commonly called a "gear install kit".
Has pinion bearings, carrier bearings, seals, all the shims you'll need for setting the gears up properly, new ring gear bolts usually, maybe a couple of other odds and ends. Plus, you'll need some fluid, and some fairly specialized tools, and some knowledge, so you don't risk destroying your gears.
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
ok thanks i know a place i can get one i was checking it out the other day thanks
http://www.ringpinion.com/ProductDet...px?ProdID=1211
just for refrence
just for refrence
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
