clutch master/slave cylinders
Old Apr 26, 2007 | 08:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
is the hydraulic slave and clutch master cylinder from 4th gen cars the same as for 3rd gen cars
Old Dec 6, 2010 | 03:44 PM
Fluentvoo's Avatar
Car: 88 Iroc (original owner)
Engine: 305TPI
Re: clutch master/slave cylinders
Did you ever get an answer for this?
I am wondering if i can use a 4th gen slave instead of a 3rd gen slave.
Simply because i have a brand new 4th gen slave. Just dont wanna put it on if it's not gonna work.
Old Dec 6, 2010 | 07:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the lt1 setup will work in a 3rd gen, and it has a nice braided stainless line on it in place of the rubber one. the lind is a bit longer, and the geometry of the pedals is a little different so with the 4th gen setup, the clutch pedal will engage rather high. It would just find for me honestly. I think if you use 4th gen pedals too, thats not an issue anymore.
i dont know if just the slave will change over, I have a feeling it does, but im not 100%
Old Dec 7, 2010 | 12:05 PM
Fluentvoo's Avatar
Engine: 305TPI
They look pretty much the same, just don't know if the shaft length or something is different. I need to replace my 3rd gen one, but have lots more to do before i get to that. Just thought since i have it in a box, and it would work i would use it. If not, I'll take it back to the store.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
